Write a script to display inactive problems with p2 incidents.
sabbani rishika
Script
12 REPLIES 12
why to use GlideRecord in client script?
GlideRecord in client side is not recommended.
I believe this is not an actual business requirement from your customer
If you still require here is the updated script
var arr = [];
var gr = new GlideRecord('problem');
gr.addQuery("active", false);
gr.addQuery('state',4);
while(gr.next()){
	var r = new GlideRecord('incident');
	r.addQuery("problem_id", gr.sys_id);
	r.addQuery('priority',2);
	r.query();
	while(r.next()){
		arr.push(gr.number.toString());
alert(arr);
regards
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
@sabbani rishika
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
Hii @Ankur Bawiskar ..The script which you have given also not working.
share your script and where have you written it
