Need help on using JSON parser in flow designer
surya123
Mega Guru
I am trying to parse a JSON payload using JSON parser. The structured payload looks like this  where I am getting the payload in a action and then using this action in the flow.
In the flow, I am calling the above action and then using for each loop and get the values correctly for id , display name etc. But when I am trying to fetch the resourceRolescope values it is greyed out. Not sure how to fetch its value.
In the log I can get the id, display value etc, I need help in adding the resourceRolescope value.
Jon23
Hi @surya123 ,
You will need to add another 'For Each Item' so you can loop through the resourceRoleScope array.  For Example:
Jon23
Hi @surya123 ,
Hi, I had tried the same earlier but then the contents within 5 in data pills is greyed out.
I added it as Available transform-> Utilities -> Get item in name/value and then it showed. This was new to me.
Sandeep Rajput
@surya123 As rightly mentioned by Jon, you need an additional For each step to loop through resourceRolescope as this property is also of type Array.
