08-18-2022 01:36 AM
Hi community!
I'd like to know if there's a way (or if it is possible) to create a report joining RITM variable sets and Multi-row Variable sets in one report.
Reporting
08-18-2022 01:45 AM
HI Erika,
You can actually report on MRVS by creating a database view, then use that view to report on
- Create a new Database view (System Definition -> Database Views)
- Give it a name like 'u_sc_req_item_multi_var'
- Label like "Multi Row Variable Set"
- Plural like "Multi Row Variable Sets"
- Description like "Joins the sc_req_item to the Multi Row variable set table to be able to report"
- Save
- Under View Tables click "New"
- Table: Requested Item [sc_req_item]
- Variable Prefix: sci
- order: 100
- Where clause: mrqa_parent_id = sci_sys_id
- Click "Submit"
- Table: Multi Row Question Answer [sc_multi_row_question_answer]
- Variable Prefix: mrqa
- order: 100
- Where clause: keep this field blank
- Click "Submit"
You should now have a DBV that looks something like this:
Create a new report
Select Table as source and select your new Database view (Multi Row Variable Set) as the table
You should now be able to create a query and select the catalog item that you want to report on that has the MRVS, as well as adjust your columns to display the Question and Value as well as any other columns you want on your report.
Referred from this thread :https://community.servicenow.com/community?id=community_question&sys_id=252bce56dbd363809a64e15b8a96...
Sandeep
04-03-2024 06:49 AM
I'm not sure I'm getting your issue, as you can see in my screenshots, I see exactly what you're requesting, using only the DB View above, and the report setup below.
04-03-2024 07:00 AM
So variables from your report are all from multirow set or from RITM also?
Just for more clarification I am adding portal form which I created:
So here, variables from Red are getting saved in sc_item_option_mtom and sc_item_option and variables marked in Blue are getting saved in sc_multi_row_question_answer.
If I remove blue from bellow view, then ONLY variables marked in red in above form will show up in report.
03-19-2026 11:14 AM
The responses I saw only explained how to combine RITM default questions to the report, not VARIBLES from your RITM.
When a report / visualization / dashboard is built simply off the sc_req_item table, one can browse and add VARIABLES quite easily.
Jon
03-19-2026 11:56 AM
Correction to my wording
Meant to say
01-16-2025 07:40 AM
