How to calculate old data values in a newly created metric definition.
Vibhuti Rajput
I have created a new metric for table change request -> field value duration -> on field state.
The metric instances are getting created correctly from the time the metric definition was created .
But our instance has changes being created from last 6 months .
How can i get their state duration so that i can report the duration correctly .
Any idea ? maybe by some background script or schedule job ?
what script to use?
Boyan1
I have done similar tasks and I have generated the metric instances retroactively, based on the data available in sys_audit table using a script job.
Let me know I shall provide you a sample script.
Best regards,
Boyan
Merzot
Hi Vibhuti Rajput,
Did the script work for you? What did you end up using? Can you please give us an update on this.
Merzot
