Is there a way to display both monthly previous and current data in PA?
tyagisu
Mega Expert
As per my requirement, I want to display success rate of change monthly. To calculate the data I am using PA. I want to show Current Month result as well as the historical data of previous months. Right now, I am getting previous month data only.
Is there a way to display both previous and current data?
Any help would be appreciated!
Su
Adam Stout
You would only see the By Month + on a time series aggregate (where the indicator was daily).  And you are seeing the April data on the scorecard but not the widget?
14 REPLIES 14
Adam Stout
Is it just skipping April?  Can you include a screenshot (blurred in required)?
Yes. Please refer the screenshot. Thanks!
Adam Stout
What time series are you using?  If it is a time rollup, make sure you have the + version (By Month + not just By Mnth).  If this is a monthly indicator, are you sure you have a score for April already or does it not collect until the month is completed?
Yes, even thought of using By month+ , but I don't get this option. I also, check if it is excluded from time series but no it is not excluded either.
Yes, we have data for April.
Oneimus
This may be old but how did you put this together
