Is there a way to display both monthly previous and current data in PA?
tyagisu
Mega Expert
As per my requirement, I want to display success rate of change monthly. To calculate the data I am using PA. I want to show Current Month result as well as the historical data of previous months. Right now, I am getting previous month data only.
Is there a way to display both previous and current data?
Any help would be appreciated!
Su
Adam Stout
You would only see the By Month + on a time series aggregate (where the indicator was daily).  And you are seeing the April data on the scorecard but not the widget?
14 REPLIES 14
Hi Tyagisu,
I am having widget which prior month data need to display with percentage ,but i brought percentage for last month and it is display july 21 with percentage and how to change to june21,if any idea please let me know on this it is urgent below screenshot for reference
Adam Stout
So the indicator is a monthly indicator and you see it on the scorecard but not the widget?
Yes, an indicator is a monthly indicator. I see 'monthly' time series on the scorecard as well as on the widget. But I don't see "By Month+" time series anywhere.
Adam Stout
Thanks a lot... this is it 🙂
