11-28-2018 02:44 AM
I am trying to use Multiple dataset to join 2 reports within a single report. As per docs i see the below image i need the same thing but unable to get that 😞
https://docs.servicenow.com/bundle/kingston-performance-analytics-and-reporting/page/use/reporting/concept/c_MultipleDataSets.html
Above image shows it combined Bar & Line report but i unable to get that. Can anyone help me out to acheive above report ????
Performance Analytics
Reporting
12-05-2018 05:01 AM
Try to make main report not Bar but rather Line and then I was able to add second dataset with more options.
11-28-2018 04:42 AM
11-28-2018 04:46 AM
11-28-2018 05:37 AM
I am not sure you can do there time based report.
They should have at least the same X axis grouping.
In order to do it you would need to somehow count avg or sum for these time scopes (months, weeks) in order to display data on the report.
You can also try to switch to PA where it is more flexible.
1st for incident counts
2nd for incident duration
You need to have good field which you will be able to use for time calculation (avg etc)
In PA you can add scripts to calculate times (minutes, hours based on start and close time of tickets).
12-05-2018 04:14 AM
Thanks for the help. I am able to get this but only problem is i unable to get a Line type along with Column report.
With both Columns i am able to acheive my report but i want to display one as Column & other report as Line thats where i am not able to get i dont know how you are able to select Line type multi dataset with parent report as Column. 😞 😞 😞
12-05-2018 05:01 AM
