Platform Analytics - Maximum Rows Default
Patrick Ouimet2
I switched to platform analytics and made a List - simple visualization type data visualization. I left the "Maximum Rows" blank, thinking it would display all data or at least display all data and then have the same page options as the old report would have had. Instead, I get 5 records and a "View All" option.
Will I need to always set the maximum rows or is there a system property that changes how this works for displaying records?
I am on Xanadu - patch 4a
11 REPLIES 11
we are planning to go to Xanadu on March 6.... so I'm a bit out on this - but I REALLY look forward to it!
Mark Manders
How is this answering the question, next to you are trying to put a spam link in your answer that doesn't make any sense at all?
it's an AI spam bot, Mark
Andrew G
I'm also stuck on this. The list in the dashboard cuts off, even when increasing the height of the list or having the max rows as a large number. It didn't used to do this pre-Platform Analytics for Reports.
Hi Andrew, did you make any progress with this issue? I'm having the same issue. Note, I am currently on Xanadu.
