My instance is not showing
spp02125
Hi Team,
Request your help retrieving my instance as all my learning is saved in it
My dev/training instance is not showing.I have my instance extended .However when i open the instance it says site cannot be reached.please take a look at belowlink
https://nowlearning-nlinst03186095-1fcnn-0001.lab.service-now.com/now/nav/ui/home
https://nowlearning-nlinst03186095-1fcnn-0001.lab.service-now.com/now/nav/ui/classic/params/target/i...
Hi @spp02125 ,
Most of the times in these cases- lost data is not recovered, we get the fresh instance only so finally your issue is resolved although Partially. Please select the appropriate answer as solution accepted and close the thread.  As per my POV- you should appreciate efforts from everyone .
Please appreciate my efforts, help and support extended to you by clicking on – “Accept as Solution”; button under my answer. It will motivate me to help others as well.
Nikhil Bajaj
ServiceNow Rising Star-2025
Hi @spp02125 ,
Nikhil Bajaj
