not able to trigger catalog client script
rajtiwari02
No value present: java.util.NoSuchElementException: No value present: java.base/java.util.Optional.get(Optional.java:143)
com.glide.ui.ng.app.AppResources$RecordAcl.ifCanRead(AppResources.java:396)
com.glide.ui.ng.NGUserProcessor.process(NGUserProcessor.java:103)
com.glide.ui.ng.AngularProcessor.process0(AngularProcessor.java:257)
com.glide.ui.ng.AngularProcessor.process(AngularProcessor.java:190)
com.glide.processors.AProcessor.runProcessor(AProcessor.java:759)
com.glide.processors.AProcessor.processTransaction(AProcessor.java:313)
com.glide.processors.ProcessorRegistry.process0(ProcessorRegistry.java:187)
com.glide.processors.ProcessorRegistry.process(ProcessorRegistry.java:175)
com.glide.ui.GlideServletTransaction.process(GlideServletTransaction.java:58)
com.glide.sys.Transaction.run(Transaction.java:2734)
com.glide.ui.HTTPTransaction.run(HTTPTransaction.java:35)
java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
java.base/java.lang.Thread.run(Thread.java:840)
I'm getting this error while refreshing catalog form in my DEV instance. How to resolve this error? and I have written client script for the catalog item but it's not triggering. Is above error could be reason if yes how to overcome. I have checked in PDI, client script is not causing any error and producing required result.
Thanks in advance!
rajtiwari02
please find the client script below :
        g_form.clearOptions('salesforce_profile_required');
        g_form.addOption('salesforce_profile_required', ' ', '--None--');
    var platform = g_form.getValue('salesforce_platform');
    // console.log("platform:", platform); // Debugging
    if (platform == 'Salesforce - OMC') {
        g_form.addOption('salesforce_profile_required', 'executive', 'Executive');
        g_form.addOption('salesforce_profile_required', 'omc_gcl', 'OMC_GCL');
        // g_form.setValue('salesforce_profile_required', 'executive', 'Executive'); // Set default
    } else if (platform == 'Salesforce - Flywheel') {
        var gr = new GlideRecord('question_choice');
        gr.addQuery('question', '1d6b2daf83dc6250a340c8efeeaad39b');
        gr.orderBy('order');
        if (gr.hasNext()) {
            while (gr.next()) {
                g_form.addOption('salesforce_profile_required', gr.value.toString(), gr.text.toString());
            //g_form.addOption('salesforce_profile_required', 'contract', 'Contract');
            // g_form.setVisible('contract', true);
            //g_form.setVisible('omc_gcl', true);
            // g_form.setVisible('executive', true);
            //g_form.addOption('salesforce_profile_required', 'executive', 'Executive');
            //g_form.addOption('salesforce_profile_required', 'omc_gcl', 'OMC_GCL');
rajtiwari02
@rajtiwari02
I already informed on Saturday (2 days ago), the error you are showing doesn't relate to any client script.
it's a system log so nothing to do with your client script
rajtiwari02
So do we have other option to check root cause of this error and why my client script is not triggering.
@rajtiwari02
coming to your 1st question, that's a generic message you can debug server side script
for your 2nd question why client script is not working?
1) are you comparing correct value in IF statement
2) did you add alert and see till which point client script runs?
