Project Workspace - Project not visible
Claudia Dahl
I have xreated a project in ServiceNow (PDI) via XML import. But the Project is not visible on the Project Workspace, even Project Manager is System Administrator, the user I am logged in.
Other Projects created manually are visible.
What could be the reason?
Not sure if selected group is correct one.
davidcmccourt
I have a similar issue. Did you manage to find a fix? Thanks in advance.
Claudia Dahl
I dod not get any response, and I also could not fix it. Hope there will be an answer soon.
RohitJ432388693
@Claudia Dahl — I tried to do the same and see the same issue. There is onbly 1 way I can see it in the Project Workspace and that is via the way I have shown in the screenshot below.
Any help here would be great!
