How to integrate Solar Winds,Rapid7,Manage Engine, MS Defender EDR this event managent tools?
Mohammed1234
Hello Team
i want know about how to integrate Solar Winds,Rapid7,Manage Engine, MS Defender EDR this event management tools with servicenow, and what are pre-requisites for this, please explain step by step for this and do the needful.
PatrickMutchler
@Mohammed1234,
This is a pretty big ask and challenging without knowing the use cases, but I'll try to get you started in the right direction.
  1. Solar Winds integration --> Take a look at this post --> https://www.servicenow.com/community/itom-forum/solarwinds-integration-with-servicenow/m-p/917168
  2. Rapid7 --> I can only tell you to check out the ServiceNow Docs page and/or the integration documentation from the Store on this. You might find this link helpful, though: https://docs.servicenow.com/bundle/washingtondc-security-management/page/product/secops-integration-...
  3. ManageEngine has a few products out there.  I am guessing that you are asking about Endpoint Central?  I recommend checking this link out --> https://www.manageengine.com/products/desktop-central/servicenow-integration-using-dc-plug-in-app.ht...
  4. MS Defender --> The instructions for installing and configuring the SIR integration with MS Defender are pretty good --> https://docs.servicenow.com/bundle/washingtondc-security-management/page/product/secops-integration-...
Apologies for all of the links.  It's always tricky answering questions like this without understanding the use cases, context of the business need, and what the end users are hoping to achieve with the integration.  I hope these at least get you started in the right direction.
**If you find that this post is helpful, please mark it as helpful.  If it answers your question, please mark it as resolved.
