need help in auto populating catalog item 1 variable values in to catalog item 2 variables
priyanka chodip
Hi there,
I have a requirement where I need to create Catalog Item 1 (considered the parent) with two variables: Manager and Employee.
Once Catalog Item 1 is submitted (ordered), it should trigger an email notification to the Manager. In the body of the email, there will be a link to Catalog Item 2.
When the Manager clicks this link and Catalog Item 2 form loads, the same two variables (Manager and Employee) on Catalog Item 2 should automatically populate with the values submitted in Catalog Item 1.
I'm not exactly sure how to implement the value passing and auto-population. Could you please guide me on how to set this up?
thanks
priya
2 ACCEPTED SOLUTIONS
J Siva
Hi @priyanka chodip
1. First build the custom URL format as required and use that in the email notification
Syntax:
https://<INSTANCE-ID>.service-now.com/sp?id=sc_cat_item&sys_id=<CAT ITEM SYS ID>&<VARIABLE 1>=<VALUE 1>&<VARIABLE 2>=<VALUE 2>
Ex:
https://dev22XXX.service-now.com/sp?id=sc_cat_item&sys_id=f15ca9c397011210e46cb73de053af7d&manager=6...
2. Create On-Load as below to map the URL parameters to the catalog itm variables.
function onLoad() {
    var manager_url = getParameterValue('manager'); // URL PARATMETER
    var employee_url = getParameterValue('employee'); // URL PARATMETER
    if (manager_url) {
        g_form.setValue('manager', manager_url); // SETTING CAT VARIABLE
    if (employee_url) {
        g_form.setValue('employee', employee_url); // SETTING CAT VARIABLE
function getParameterValue(name) {
    var url = top.location.href;
    var value = new URLSearchParams(url).get(name);
    if (value) {
        return value;
Siva
Ankur Bawiskar
@priyanka chodip
if you are using flow designer then check my blog on how to add link and in that LINK to 2nd catalog item include the variable values for both the variables, then use onLoad catalog client script on 2nd item to get the values from URL and populate them
ServiceNow Flow Designer: Adding Record Link in "Send Email" flow action
1) form the URL like this /sp?id=sc_cat_item&sys_id=catItemSysId2&sysparm_manager=<flowVariableManager>&sysparm_employee=<flowVariableEmployee>
2) onLoad catalog client script
function onLoad() {
    try {
        if (window == null) {
            // for portal
            var manager = new URLSearchParams(url).get("sysparm_manager");
            var employee = new URLSearchParams(url).get("sysparm_employee");
            g_form.setValue('managerVariable', manager);
            g_form.setValue('employeeVariable', employee);
    } catch (ex) {
        // for native
        var gUrl = new GlideURL();
        gUrl.setFromCurrent();
        var manager1 = gUrl.getParam("sysparm_manager");
        var employee1 = gUrl.getParam("sysparm_employee");
        g_form.setValue('managerVariable', manager1);
        g_form.setValue('employeeVariable', employee1);
J Siva
Hi @priyanka chodip
Syntax:
Ex:
function onLoad() {
    if (manager_url) {
    if (employee_url) {
    if (value) {
        return value;
Siva
Hi Siva,
Thanks for replying, im doing it via flow designer send email action and i guess i can't make custom url.
and i can't give the variable values directly on the url because its not dynamic, im not sure what user will pick.
@priyanka chodip
Ok. In this scenario, use "Send Notification" flow action instead.
So that, you can utilize the email scripts to populate the hyperlink url dynamically.
Updated:
As Ankur mentioned, you can utilize the flow variables. Create one flow variable and te set the catalog variables as below.
Sample:
<a href="/esc?id=sc_cat_item&sys_id=<CAT ITEM SYS ID>&<VARIABLE 1>=<VALUE 1>&<VARIABLE 2>=<VALUE 2>">Link</a>
Nilesh P
@priyanka chodip In your "Send Email" step, you can dynamically create the URL using data pills from the Catalog Item submission. Let’s say: Manager = trigger.current.variables.manager
