(White Paper) Incomplete IP Identified Devices and what to do with them
04-04-2022 04:27 AM
- 10,527 Views
07-06-2026 03:03 AM
Hello Chris,
Usually an unmatched Discovered Item from class "Incomplete IP Identified Devices" is pointing at a record from the table cmdb_ci_incomplete_ip -> Both the DI and the CI record in the cmdb_ci_incomplete_ip get created upon ingestion.
After a while, either from an improved lookup rule or some other improvement, the Discovered Item gets successfully matched and it starts pointing to another CI -> the actual CI from the cmdb_ci table, which makes the initial CI of the class "Incomplete IP Identified Devices" actually orphaned.
Do you have any suggestion on how to keep and maintain the cmdb_ci_incomplete_ip table from orphaned records?
