07-05-2026 03:41 AM
When I try to log in to ServiceNow University, I don't receive the MFA code via email—not even in my spam folder—and I am unable to log in.
07-05-2026 07:45 PM
Hi @ssbino ,
In that case, you could try sending mail to ServiceNowUniversity@servicenow.com and they would make it to the directed team so that your issue could be solved.
Let me know once you tried and results pls
If you found this helpful, please mark it as Helpful and Accept as Solution so it can reach others too.
Thanks & Regards,
Sachin Narayanasamy
07-06-2026 01:44 AM
ahoy @ssbino,
if you have issue with logging to the SN University, navigate to the login page:
https://signon.servicenow.com/x_snc_sso_auth.do?pageId=login
and click the button below hihghlighted in green:
It will let you contact the proper team to assist you.
Unsolicited advice - after this is resolved, configure the MFA with authenticator app as well, not only email but also this alternative.
07-06-2026 02:45 AM
It’s resolved; I spoke with SSO support and also sent an email to ServiceNowUniversity@servicenow.com.
Afterwards, I tried logging in using Incognito mode; I’m not sure exactly what fixed it, but I managed to get in via an Incognito tab.
I’ve since set up other authentication options just in case I run into issues later on—thanks to everyone for the help.
07-05-2026 11:25 AM
Hi @ssbino ,
Yeah as Abira Kundu said you can try that approach itself it would definitely solve your issue easily.
Thanks & Regards,
Sachin Narayanasamy
07-05-2026 08:56 PM
Please check your spam/junk folder as well as any email quarantine or safe-sender filtering your organization may have in place, since these can sometimes block the MFA email before it's even flagged as spam. If the code still doesn't arrive after a few minutes, try requesting it again, and use an alternate MFA method (such as an authenticator app or SMS) if one is available on your account. Should the issue persist, please escalate this to ServiceNow University support so they can investigate further from their end.
07-06-2026 01:44 AM
ahoy @ssbino,
07-06-2026 02:47 AM
07-06-2026 03:47 AM
excellent @ssbino! I am glad it's resolved
