Changed from workflow to flow designer - non admin not working
02-24-2025 07:12 PM
Here is the scenario, I have a catalog form which was connected to workflow and was working fine. Now I have changed workflow to flow designer and all works fine for me as I have admin access. However, for the non admin users its not working. The Flow fails saying some security restriction error.
I have verified that the Run as is System User. Also tried creating a ACL for create record access to sc_task table and catalog variable table. Nothing worked, please suggest.
Thanks in advance
02-24-2025 10:53 PM
Hello @joshuastanley
Can you cross check that when this action is running in flow context what is run as coming as?
Also, ACL you created is it of type write?
Thanks & Regards
Viraj Hudlikar.
02-24-2025 08:14 PM
Please check if your issue is related to below support article.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0870023
02-24-2025 09:28 PM
what error it throws at Create Catalog task step since you said you already created the ACL?
also check this KB
02-25-2025 07:19 AM
Thanks all for the responses. I already looked at the above article and applied the ACL. however, still facing issue.
02-25-2025 07:24 AM
@joshuastanley What type of ACL you created on sc_task and sc_item_variables_task table? also the role you mentioned in the ACL?
