ACL Issue in Flow When the Flow is triggered by the System
Rohit_Singh_19
Hi All/ @Ankur Bawiskar
I have a flow which is triggered at 4:00 AM GMT. Now in that flow I am using look-up record for the table X and then sending an email using Send Email Action. In Send E-mail body I am using Table X record attributes using data pili picker. When I am testing the Flow using Test UI Action in flow I am not facing any issue. My Flow Properties is set as Run As - User Who initiates the session.
However, when the flow is getting triggered by the system at 4:00 AM GMT. I am getting an error while sending email.
I tried to change the Flow property to Run As - System User. Now when I am testing it manually through UI Action I am getting the same ACL error.
My understanding is when the flow is initiated by the system then the all the ACL's are evaluated to true.
Error: Email validation failed: ACL restricts retrieval of the record: Table Name of X Sys_ID of the table record
Note: The Flow and Table X both are in same application.
13 REPLIES 13
Ankur Bawiskar
@Rohit_Singh_19
is that a scheduled flow?
share some flow config screenshots.
Hi @Ankur Bawiskar , Yes, it's a scheduled flow.
Error: Email validation failed: ACL restricts retrieval of the record: (Table Name of X) (Sys_ID)
@Rohit_Singh_19
Since it's a scheduled flow why not set it with System User
Why to keep user initiating the session?
Hi @Ankur Bawiskar , So I did tried to change the flow property to System User. Then when I am trying to test the Flow manually through Test UI Action. I am still getting the error.
Also I have waited for the flow to execute as per the schedule with System User Property setting and but still getting the same error.
@Rohit_Singh_19
the table being looked upon in Step 1 has what ACL?
did you check that?
