client script doesn't work with passing sys ids
service buzz
Hi Team,
I have  written a client script on change to make the field invisible for some of the companies .
   alert('enter change');
    if(company == 'fa652899db674410e2604f7405961985' ||'62652899db674410e2604f740596193c'||'02b56cc91beaf098bbc299b59b4bcb98'||'6a65e499db674410e2604f74059619ef'||'d48428c8db730594dd7efad3f3961917'||'58472644dbd1f414e57455fbd39619d4')
if(det_con == 'yes')
        alert('enter if');
        g_form.setMandatory('loc_it',false);
     g_form.setDisplay('loc_it',false);
this is not working any thing wrong with syntax because it always high light the if line where company sys ids are provided
I realized that and added in the below script
service buzz
det type is yes/no
Hi @service buzz ,
You mean True and False correct ?
So in that condition you write your client script like
if (det == true) {
  // do something
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
Birla_Krushna
Hi @service buzz
You need to modify your code as per below code. Can you try below code,
// Assuming company, det_con, and g_form are defined elsewhere in your script
var company = g_form.getValue('company');   //Use backend value of that field
var det_con = g_form.getValue('det_con');  ////Use backend value of that field
if (company == 'fa652899db674410e2604f7405961985' ||
company == '62652899db674410e2604f740596193c' ||
company == '02b56cc91beaf098bbc299b59b4bcb98' ||
company == '6a65e499db674410e2604f74059619ef' ||
company == 'd48428c8db730594dd7efad3f3961917' ||
company == '58472644dbd1f414e57455fbd39619d4') {
if (det_con == 'yes') {
alert('enter if');
g_form.setMandatory('loc_it', false);
g_form.setDisplay('loc_it', false);
This will definitely helps you to resolved your issue. Let me know in case you need to understand the flow or you can DM on LinkedIn.
If this solution resolves your query, kindly mark it as the accepted solution and give it a thumbs up.
Best Regards,
Krushna Birla
