Close Tasks from flow designer automatically
Nico12
I have created a flow designer to update manager field on user form from a catlog item and it work perfectly.
The only thing is that i want sc_tasks, and so RITM and REQ to auto close when the updating is done.
How i could achieve this.
Here is my flow :
I tried on last action to set this but it didn't work :
Is there a way to close the task /RITM / REQ ?
Uncheck the "Wait" option on the "Create Catalog Task" activity. And make sure the order of activities remains
- Create Catalog Task
- Update Manager
- Close Catalog Task.
12 REPLIES 12
Nico12
Thanks Janos, it worked.
You're most welcome 🙂
Hi Janos,
One last question.
When i try to close my Task, in the activty log i see that the state updated to "closed completed" but not on the form field.
Activity log :
Form field :
Do you have any clue why the state does not change in the field ?
Not even after a refresh of the closed task?
Unfortunatly no.
