Create popup dialog box when user click problem_task Re-Assess UI action
Arun33
Hi Everyone,
I have "Re-Assess" UI action that I need to display a pop-up for with a comment box. They need to write the reason for the Re-Assess.
After they click ok, the reason comment should populates in worknote.
I have create UI Page for this.
and Re-Assess UI Action
but it's not working can someone help me on this
2 ACCEPTED SOLUTIONS
Hi Anubhav,
UI Page
UI Action
Now the issue is am not able to add Re-Assess Reason in WorkNote when problem task is in close state.
Hi Anubhav,
I have checked with this as well but able to add worknote at close state.
9 REPLIES 9
Hi @Arun33
Have you not tried to achieve it using 'prompt()' function I mentioned?
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Anubhav Ritolia
ServiceNow Rising Star 2023
No that is also not working
Hi Anubhav,
i have modified some ACL now i am also able to add thanks .
Hi @Arun33
If my solution helped you reach to the solution, please mark my solution as correct answer.
Anubhav Ritolia
