Decimal field max length
Chuckie
Hello - i have created a new filed - which is a Decimal Type.
I have a requirement for that field to show up to only 5 decimals. And so i made max length = 5. However, when i save the record and it refreshes, it sets it to 15.
What can i do so that field is populated w/ a number only up to 5 decimals?
There is a workaround given in KB0696658, did you try those steps.
I am facing the same issue. Can anyone help?
Hi @Chuckie ,
Checked one decimal type field value in my incident table but there is no option given for regEx. However there is other option [ Dictionary Attributes ] which you can try to limit the decimal places.
https://docs.servicenow.com/bundle/utah-platform-administration/page/administer/reference-pages/conc...
