Fix Script against Scoped Applications
Hema2
Giga Contributor
I have created Global Fix Script to create records in one of my scoped applications. But, I got below error.
"Security restricted: Create operation against 'x_486589_demo_scoped_application' from scope 'rhino.global' has been refused due to the table's cross-scope access policy"
Note: I have used 'update()' method to create records.
Later, I have created fix script in my scoped application then it worked.
Can anyone explain what cross-scope access policy, which is mentioned in above error?
Thanks in Advance!
Hema
14 REPLIES 14
Hi Ankur,
Please refer to the snapshot and the script.
Script:
var today = new GlideDateTime().getDate();
var gr = new GlideRecord('x_demo_custom_table_1');
while(gr.next())
       var kd = gr.u_glide_date_1.getDisplayValue();
       var id = gr.getValue('sys_id');
      if(kd == today)
           var gr1 = new GlideRecord('x_demo_custom_table_2');
           gr1.initialize();
           gr1.insert();
Hi Hema,
I assume you have set Can Create, Can Update on this table "x_demo_custom_table_2"
If yes then it should work.
Try clearing instance cache using cache.do and then logout and login again
Hi Ankur,
Thank you for your quick replies.
I have tried after clearing the instance cache as well but, still no luck. I am not sure where I am exactly doing wrong.
Could you please give a shot from your end if possible.
Hema
Hi Hema,
Did you try adding logs?
while(gr.next())
      if(kd == today)
           gs.info('Inside creation');
           gr1.initialize();
           gr1.insert();
If this is for your PDI then share url, also create some admin user and share credentials (username, password) then it can be checked
Pradeep Sharma
Hi Hema,
Please share the steps to reproduce this issue. I have also covered on this topic in my blog here. You may find helpful. Securing an application using Cross Scope Access, Application Access Settings & Restrict Table Choic...
- Pradeep Sharma
