Fix script- Progress Controller was left in running state on startup
Priyanka_786
Hi Community,
Hope you are doing well.
I am facing issue with fix script execution in prod environment. That is fix script got auto- cancelled with this message "Progress Controller was left in running state on startup" show progress workers logs. Due to this data was not properly updated as expected.
This same script tested and ran in pre-prod environment as expected without this error. So there is nothing wrong in code logic. One difference is with data count which is greater in prod.  I wanted to understand the cause of this behavior.  Has anyone encountered this problem? if yes, any leads  would be highly appreciated.
Priyanka Salunke
Priyanka_786
@Shivalika  and @Ankur Bawiskar : Thank you for your prompt responses and sorry to late reply.
After further investigation with admin team it was due to node failure issue. Meaning Node got stuck for long time. After restarting node, it solved issue.
Priyanka Salunke
Ankur Bawiskar
@Priyanka_786
Does your fix script update record with setWorkflow(false)?
Share the script.
Try to run the fix script in chunks.
Example: if you know there will be 50k records then run 5 fix scripts 1 each for 10k records
Shivalika
Hello @Priyanka_786
Yes, it happened because of data size, at some point in the middle while updating the data the transaction would have been timeout. But the fix script was still waiting, leading to this error message - as in running state.
So, yes it's always recommended to update any data in production in chunks and not exactly 10k - but depending on the size of per record, like it should exceed 100 MB of data update. So if you are updating some very big table as such cmdb_ci, then reduce even more to 5k perhaps, but if it's some less size table like user table - do it 10k.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Priyanka_786
Priyanka Salunke
Hi Priyanka,
Which node you are referring here for this issue. I have tried restarting mid server but again same error every time the record count increased by 100-200 but its not processing completely.
