Fix script- Progress Controller was left in running state on startup
Priyanka_786
Hi Community,
Hope you are doing well.
I am facing issue with fix script execution in prod environment. That is fix script got auto- cancelled with this message "Progress Controller was left in running state on startup" show progress workers logs. Due to this data was not properly updated as expected.
This same script tested and ran in pre-prod environment as expected without this error. So there is nothing wrong in code logic. One difference is with data count which is greater in prod.  I wanted to understand the cause of this behavior.  Has anyone encountered this problem? if yes, any leads  would be highly appreciated.
Priyanka Salunke
Priyanka_786
@Shivalika  and @Ankur Bawiskar : Thank you for your prompt responses and sorry to late reply.
After further investigation with admin team it was due to node failure issue. Meaning Node got stuck for long time. After restarting node, it solved issue.
Priyanka Salunke
Hi @AshishS18 ,
That action was done by admin team .so I am not sure which node they exactly restarted.
Priyanka
