06-04-2020 04:20 AM
I'm trying to use a plugin (F5 BIG-IP Spoke) in the flow designer for an application from my company. However, when I test I get the error "Unable to load connection with alias ID: a4c9950edb40ef009a985404ce961952 Open Connection Alias".
What does that mean?
I already configured "Run As - System user" in properties
Flow Designer
06-04-2020 05:35 AM
Navigate to sys_db_object
Search for basic_auth_credentials table
Open the record
In the application access tab check if the setup is same as what i gave in the screenshot.
06-04-2020 04:57 AM
Is here?
06-04-2020 05:35 AM
Open the record
10-24-2022 12:19 PM
09-08-2023 08:21 AM
It is the same setup, but I am still facing the issue while a non-admin makes a change to the record, it triggers the flow but gives an error "unable to load connection alias".
How it is resolved? Can anyone help on this?
04-15-2024 01:27 AM
Please help me on the same.
Where you able to resolve it??
