Flow Designer failing because of alias connection?
Leonardo Ferrar
Kilo Expert
I'm trying to use a plugin (F5 BIG-IP Spoke) in the flow designer for an application from my company. However, when I test I get the error "Unable to load connection with alias ID: a4c9950edb40ef009a985404ce961952 Open Connection Alias".
What does that mean?
I already configured "Run As - System user" in properties
Navigate to sys_db_object
Search for basic_auth_credentials table
Open the record
In the application access tab check if the setup is same as what i gave in the screenshot.
martinLP86
same issue as above. Thank you in advance
