Flow Designer Get Catalog Variables not working for Multi-row Variable Set
JC S_
Mega Guru
We've set-up a Multi-row Variable Set and we can't seem to use the values from MVRS on Flow Designer Get Catalog Variables action. How are we supposed to utilize the user input from MVRS on our workflow if we can't get the values? Is this a Flow Designer limitation? Any ideas for a workaround?
12 REPLIES 12
Meshia
Did you ever find something that worked?  The response below didn't work for me.
We are still not able to call the values from the multi-row variable set as of today.
1234567789hrebn
Hi All ,
i was struck somewhere can you please give me steps to call multi row variable set in to flow designer created action as mentioned above but unable call that in flow designer
I was never able to do it in Flow Designer.  I had to use the work flow editor to build a workflow for MR variables which it seems to work great for.  I'd also put a ticket in to HI about using them with flow designer they advised it's an enhancement in progress for a future release (not sure when it will be released).
This is what was told to me
"There is a PRB (PRB1315445) opened for the issue and is considered as "product Enhancement".
You will be seeing this feature in upcoming versions. "
