Flow Designer Manual approver issue
adam5646
Hi Team,
Need your help regarding a Flow designer issue - manual approvals - after approval TASKs are not generating.
When 2 manual approvers are added and 1 approver approves it and the 2nd approver is removed, It is still waiting at the Ask for Approval and further task(s) don't get generated.
Task should generate even if we remove the approvers manually as it happens in the workflow.
@adam5646,
Flow Designer can be finicky every now and then, have you tried removing the Approval Step completely, publishing the Flow, re-adding the Approval Step and then publishing the Flow again?
