Flow variable reference field does not populated in the flow
SiarheyV
I created reference variable to the group in the flow and try to use parent field of this variable in the approval. And I see that this value is empty in the flow context. I found work around for this issue. I add look up record to the group with my group variable and use in the approval reference to the parent from this action. Is it a SN bug or I am doing something wrong?
Elijah Aromola
Can you share a screenshot of your configuration?
vs14
