Having issues with a script
‎07-11-2017 05:01 AM
I am currently working on the training module (Integrating with ServiceNow; Exercise: Create an inbound web service) and the script that is provided is invalid. I am looking for some help/guidance on how to fix it so I can move forward with this training.
Error: "Could not save record because of a compile error: JavaScript parse error at line (27) column (2) = syntax error (<refname>;line 27)
//Convert source field to string
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
var name = source.u_name.toString();
//Split names anywhere there is a space
var split_names = name.split (" ");
//Find the number of names
var num_names = split_names.length;
//If there is only one name map it to the last name
if (num_names == 1) {
target.last_name = split_names[0];
//if there are two names map to first and last name
if (num_names == 2) {
target.first_name = split_names[0];
target.last_name = split_names[1];
//if there are more than 3 names combine into one middle name
if (num_names >= 3) {
target.first_name = split_names.shift();
target.last_name = split_names.pop();
var middle_name = split_names.join(" ");
})(source, map, log, target);
Thank you,
Lindsey
‎07-11-2017 05:50 AM
Yes, it's Syntax error
‎07-11-2017 05:57 AM
Hi Herman,
You have used split_names[0], but you have defined an array. once check with that.
regards,
Sadasiva
Please mark helpful/ correct based on the impact
‎07-11-2017 05:58 AM
Shiva, that worked, thanks so much for your help!
‎07-11-2017 06:00 AM
You're welcome.
Good syntax indentation makes this error easier to detect. Dedicated code editor enforces clean indentation.
