How can i switch to Servicenow Native UI from App engine studio?
aditi sharan1
I created a PDI and its redirecting me to app engine studio whenever i login, i want to work on the native ui , so how can i see that ?
I have the admin role too
Hi @aditi sharan ,
Your instance is using san diego release.
You just need to click on"ALL" on the left top corner of your screen and you will get your apps navigator , etc..
like below:
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
suchitramod
Steps to resolve this issue:
1. Go to developer site homepage (https://developer.servicenow.com/)
2. Click on "Manage My instance" button
3. Click on "Actions" menu
4. Select 'Change User role'.
5. Select 'Admin' and click on 'Change'.
6. Open the PDI using "Start Building" button
Now you will be redirected to Native view.
