09-02-2020 02:31 AM
I have created a Flow designer which has two sub-flows and one custom action now i have to move it to higher instance, As while creating i have not capture them in separate custom update set. Now I am facing issue capturing them in an update set, As i have to move them.
I want to understand how flow designer gets capture in an update set, if i make a small change will it capture entire flow ? please help me to resolve this.
Shaikha.
Flow Designer
Multiple Versions
Workflow
- 21,409 Views
09-03-2020 10:08 PM
Thank you for your response!
I have copied the flow and given a new name being on my correct update set and moved it to higher instance.This way all actions got captured.
09-03-2020 12:51 AM
Thank you all.
This is my findings, I have service catalog trigger and service tasks with stages, if i republish stages are not getting captured in update set.
Thank you.
shaikha.
09-03-2020 12:56 AM
Are you saying that stages were captured first and now with republish they are not capturing?
09-03-2020 01:02 AM
I have created Flow in default update set now i am trying to capture in custom update set and move to higher instance. so if i republish being on correct update set stages didn't got captured.
Thank you,
Shaikha.
09-03-2020 01:16 AM
Hi, go to those specific actions which are not captured. And check if there is a link "Add to update set". If yes click on that to manually add them to your update set.
09-03-2020 05:26 AM
Hi Shaikha,
Hope your update set and flow are in the same scope. OR
Maybe start creating a new Flow/Workflow from scratch in Development instance this time properly in your update set. And Later inactivate the earlier one.
Saji
