09-02-2020 02:31 AM
I have created a Flow designer which has two sub-flows and one custom action now i have to move it to higher instance, As while creating i have not capture them in separate custom update set. Now I am facing issue capturing them in an update set, As i have to move them.
I want to understand how flow designer gets capture in an update set, if i make a small change will it capture entire flow ? please help me to resolve this.
Shaikha.
Flow Designer
Multiple Versions
Workflow
- 21,409 Views
09-03-2020 10:08 PM
Thank you for your response!
I have copied the flow and given a new name being on my correct update set and moved it to higher instance.This way all actions got captured.
09-03-2020 10:08 PM
09-04-2020 05:36 AM
Awesome Shaikha,
Request you to please mark the thread as answered and close this open issue/query.
Saji
09-04-2020 09:39 PM
Hi Shaikha,
Please confirm if your issue was resolved so that you can close this open thread and it can be benefit for others in the Community.
Saji
09-09-2020 06:31 AM
Hi
Please close this open thread if your issue is resolved so that others in the Community can benefit from this.
Appreciate your response.
Saji
02-05-2021 01:34 AM
Can some one answer for below queries.
I have created a flow designer to create a records in following tables but all these are captured in Default(Global) update set (Even I have active update set). How can I set a logic to capture it in specific update set.
Tables:
Application Registry (Oauth_entity)
Rest Message(sys_rest_message)
HTTP Methods (sys_rest_message_fn)
Catalog Item (sc_cat_item)
catalog variables..etc
Please suggest an approach to solve this. Thanks.
