09-02-2020 02:31 AM
I have created a Flow designer which has two sub-flows and one custom action now i have to move it to higher instance, As while creating i have not capture them in separate custom update set. Now I am facing issue capturing them in an update set, As i have to move them.
I want to understand how flow designer gets capture in an update set, if i make a small change will it capture entire flow ? please help me to resolve this.
Shaikha.
Flow Designer
Multiple Versions
Workflow
- 21,409 Views
09-03-2020 10:08 PM
Thank you for your response!
I have copied the flow and given a new name being on my correct update set and moved it to higher instance.This way all actions got captured.
02-05-2021 03:50 AM
Hii Seenivasan,
You cannot capture record creation in an update set , Look at the article to understand what all can be stored in an update set
If you are looking to capture flow designer in update set then it is better to just make your active update set(in which you want to capture this FD) as current & then copy the flow and give it new name and publish it this way it will be captured in your current update set.
Mark helpful if it helped you!
Shaikha.
10-23-2025 07:26 PM
I want to bring this back up. I am trying to do the same but when I export and import the update set with the flows in them, I get multiple errors around "Could not find a record in sys_hub_flow_version for column version_record referenced in this update " in the new instance. What can I do?
