How to fetch reference field data in catalog client script or in script include
Ulka1
Hi Expertise,
I need to fetch reference field(like caller) data such as location which is stored in sys_user table and then I have to use this location in catalog client script. so please could anyone suggest me how to achieve this one. I tried getReference method but it is not working.
Awaiting for your response.
Thank You,
Ulka
22 REPLIES 22
then this should work fine
Please check if the alert comes?
var subjectPerson = g_form.getReference('subject_person',doAlert);
function doAlert(subjectPerson)
	if(subjectPerson.location == 'locationSysId'){
		alert('Inside if');
		g_form.setValue('fieldName', 'fieldValue');
alert is not displaying.
please share complete script here and the configuration screenshot.
also share the form screenshot
Shakeel Shaik
var subjectPerson=g_form.getReference('subject_person',doAlert);
if(subjectPerson.getDisplayValue('location') == 'XYZ')
g_form.setValue('field Name', subjectPerson.getValue('location'));
Imran Ahmad1
Mega Guru
Hii @Ulka
Copy and paste the code in your client script:-
var user = g_form.getReference("caller_id",callback);
function callback(user){
if(user.getDisplayValue("location")=="ABC"){
g_form.setValue("field name",user.location);
Imran Ahmad
If Correct Mark as Correct Answer:-
Please Mark Helpful below:-
