‎09-29-2020 12:11 PM
I am trying to create a flow which will perform sequential approvals for a record, but it doesn't seem like Flow Designer supports this.
The scenario is a given record has 3 different people that need to approve, but sequentially. This means that Approval A should trigger first, and once that person approves, then Approval B should occur, then Approval C. Then only once all three have approved should the approval field on the record be marked as approved, but if any of them reject along the way the flow should stop and the approval on the record be marked rejected.
The behavior I am seeing when setting this up is that if you set up each approval activity to approve or reject, when the first approval is done, the record is approved then when the next approval is generated, the approval is set back to requested and this continues until the final approval leaves the approval as approved. I tried setting the first two approvals to only Reject if anyone rejects, but what happens when they're configured that way is the first approval is approved which leaves the approval field as requested but when the next approval in the sequence is generated, the approval field is changed back to Not Yet Requested and then immediately back to requested.
What I am looking to do is to have the first two approvals set the approval field to rejected if they are rejected, but if they are approved to simply leave the approval field as requested until the last approval is completed and then set the approval field value to either rejected or approved based on the outcome of that last approval.
If anyone has any insight on how to configure a flow this way it would be greatly appreciated, thank you!
Flow Designer
- 22,706 Views
‎01-12-2023 07:27 AM
Unfortunately I haven't, the best I could do is to chain Ask for Approval actions where all but the last approval in the chain has it's approval rule set to reject when anyone rejects and the last approval is set to approve or reject when anyone rejects.
This still causes the Approval field to jump back and forth between Not Yet Requested and Requested but at the end of the day it works to create the approval chain. Just be careful that you don't have any logic running on the Approval field that is triggered when the value changes to Requested, otherwise that will trigger for each new approval that is generated.
‎05-05-2021 04:18 AM
Hi Jordan.
I have the same Problem.
Have you been able to find a solution for this?
‎11-25-2021 05:10 PM
I had the similar problem, and was able to address it using a sub-flow for the approvals. Based on checking a sub-flow had a wait option, wherein the approval won't proceed to the next activity until the sub-flow was completed.
Sample Sub-flow:
and this is the structure of our flow for reference:
Hope this can help. Have a great day!
‎02-15-2022 02:44 PM
The solution proposed here did not help me either. The Approval field keeps switching from Approved to Requested when a new approval is requested... instead of the field getting updated when there are no more approvals (or when 1 is rejected)
‎02-24-2022 03:49 AM
I have a similar requirement.
Was anyone able to overcome this issue. Please share if any idea on how to overcome this.
‎02-25-2022 01:36 AM
hi,
can you provide more informations about your issue?
thx
