How to simulate Approval Coordinator in Flow Designer?
Erik Gunther
How can I create the same functionality as an Approval Coordinator in Workflow Editor? My key issue is that I need to run multiple individual or group approvals in parallel. In Flow Designer, if I try to create parallel approval activities, the functionality is not the same because any one approval then triggers the others getting marked as "No longer needed".
Mart Sinimaa
I'm also trying to achieve this solution on flow but it seems it's not possible on Flow. Workflow had this Approval Coordinator action but this is missing from Flow. Unfortunately we can't run workflow under flow as well (if workflow is created for sc_req_item table) https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0751705
