I am trying to concatenate two reference lists, and no matter what I do I end up with weird stuff
verdakosnett
I tried many things but here is my latest attempt that creates the above mess:
var assigned=org.name.toString().trim();
mainTasker.u_glide_list_3=mainTasker.u_glide_list_3.concat(assigned+', ');
Abhinay Erra
Before going into the code, are these three list fields on the same table? If yes, then the following code will work
var arrayUtil = new ArrayUtil();
var a1 = gr.<list1 field name>.toString().trim().split(',');
var a2=   gr.<list2 field name>.toString().trim().split(',');
gr.<list3 field name>=arrayUtil.union(a1,a2).join();
gr.update();
to remove the error, you may try adding "global."   before "ArrayUtil();". So the second line in your script would be
var arrayUtil = new global.ArrayUtil();
verdakosnett
Thanks Abinay and John. It worked great!!
