Include CI's for child classes on reference qualifier.
Shane Vidal-Hal
Is it possible to create a configuration item reference qualifier to return all CI's from a parent class and include child class CI's as well. Currently you can specify individual classes but I would like to return all CI's below the server class for instance. I see there is a field called sys_class_path. Could this be used?
srphayre
Giga Contributor
Hi Shane,
There is a function called getTableExtensions which returns all of the extended tables from a base table.
More info here: https://developer.servicenow.com/app.do#!/api_doc?v=kingston&id=r_TU-getTableExtensions
Hope that helps!
Steve
ITSM Guy at Expedia Group
srphayre
Giga Contributor
Hi Shane,
Hope that helps!
Steve
Shane Vidal-Hal
Hi Steve
Thanks this is eaxctly what I needed. I can now extract all the table names and compile a list of CI's from all child tables using a script include.
Shane
Dominik Simunek
Hi all,
In case somebody finds this thread, I want to give it an update here. There is a nice feature which can be used in reference qualifiers and encoded queries - it is "INSTANCEOF" operator which allows you to easily query a base table with query like "sys_class_nameINSTANCEOFcmdb_ci_server" and it will return you all records from child classes (e.g. Windows Server, Linux Server etc.).
https://docs.servicenow.com/bundle/rome-platform-administration/page/script/server-scripting/concept...
You can also easily use it in the Condition Builder like "Class IS A Server". The operator "IS A" means "INSTANCEOF" while operator "IS" means simple equal operation. I found this super helpful and super easy. No need to script something to get CIs from a class including all the child classes.
Best regards,
Dominik
Thank you! The "IS A" saved us from extra coding to show all the children of a parent class (outside of cmdb_ci).
