Is it possible to add minimum character required for 'Multi-line text' variable type in Service Catalog?
2022_ServiceNow
Hi everyone,
Is it possible to add the minimum characters required to the catalog field of variable type multi-line text?
Eg: I want a user to at-least write 30 characters before submitting.
Priya
Muhammad Khan
Use onSubmit()/onChange() catalog client script as per your requirement.
function onSubmit() {
    if(g_form.getValue('<multi_line_variable_backend_name>').length < 30){
		g_form.showFieldMsg('<multi_line_variable_backend_name>', 'Enter at least 30 characters.', 'error', true);
		return false;
15 REPLIES 15
Murthy Ch
Hi Priya,
MY bad:(
So far, I was checking for single line text. If it is Multi line use onSubmit CS only.
AS per above replies make sure to check UI Type as ALL to work for both serviceportal and native UI.
BTW Thanks Pavan for correcting me.
Murthy
