Is it possible to dot-walk using a reference variable in a report?
02-22-2016 08:01 AM
Is it possible to dot-walk using a reference variable in a report? I've tried using reports that point to a database view (sc_task and sc_option_item_mtom tables), a variable log report and sc_request_item however cannot see how to dot-walk using a reference variable that points to the location table so that I can pull additional location information. What am I missing?
- 11,335 Views
04-28-2017 08:40 AM
Hi Billi,
I have exactly the same question. Were able to figure this out? Is adding the reference variable attribute as a variable on the form is the option left ?
Thank You
Rey
03-26-2018 09:54 AM
Did you ever find the solution to this issue?
09-15-2020 09:59 AM
Santosh
02-27-2024 01:46 PM
Did anyone ever find a way to do this? Specifically dot-walk through on a referenced value that is in a variable on a catalog item form.
02-28-2024 04:04 AM
If you're using a conventional condition builder it SHOULD be as simple as "walking" through the Question or Variable "field" in the field list. I demonstrate it on this video
