Is there any way to activate JIRA spoke on PDI,without integration hub's subscription package.
Aindrila Mondal
I need JIRA Spoke for bi-directional integration between SNOW and JIRA,but not with HI credentials or Subscription,is there any way in between?
Marwan_
Mega Expert
Hi @Aindrila Mondal
If you are looking for a solution for Bi-Directional integration between ServiceNow and Jira without using Integration Hub. Look into the Exalate Solution that provides integration + full control of the rending and receiving data and data handling on both sides.
Also please provide some insight to your desired use case for this integration and what kind of action/information you would like to exchange between the two platforms.
Kind regards,
Marwan
yeah,already activated integration hub plugin from PDI,but thats not resulting into the availablity of the Jira spoke plugin
@Aindrila Mondal
That's correct.
JIRA spoke seems not available for PDI.
I couldn't find it in plugins from developer portal and also from instance plugins module as well
refer this link
How to set up Jira Spoke
@Aindrila Mondal
Hope you are doing good.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
Hi Ankur,
not able to find JIRA spoke.
Nikhil
Marwan_
Mega Expert
Hi @Aindrila Mondal
Kind regards,
Marwan
