Max length for an Int field not working?
Mitch Moses
Giga Expert
I think its a bug in SN. If you have HI account, post a request there and they should help you.
Regarding the fix, you can use client script.
Write a onchange client script on your Bridge meeting field like below
	if(newValue.length>1) {
		g_form.showErrorBox("u_bridge_meeting","You cannot enter more than 1 digit",true);
Mark the comment as a correct answer and also helpful once worked.
9 REPLIES 9
It works.Javascript converts it implicitly. Already checked in my dev instance before sharing the code.
Abhinay Erra
You can use on change client script for that and validate number of digits entered.
Abhinay Erra
Replace comma before checking the length.
g_form.getValue("u_bridge_meeting").replace(/,/g,'').length;
Hi Mitch
It might not require as you are only checking for a length of 1. The comma gets added only after 3 digits.
Please mark my comment as a correct answer and also helpful once worked.
Priti Golam1
Hi Mitch,
    You can refer the below link, In this link this is specially mention that
  • You can only change this value for a String field. Changes for any other type of field are ignored.
 https://old.wiki/index.php/System_Dictionary
For your refrence i have attached one image kindly go through it.
If you found my answer helpful kindly mark it as helpful or correct
Thanks and Regards,
 Priti Golam
