Multi-Row Variable datapills greyed out in Flow Designer
Rosemary4
My personal dev instance is on Rome. I'm trying to use the value from one of the columns of a multi-row variable set in a For Each loop to lookup the sys_ids in sys_user. The steps I've take are:
1) Get Catalog Variables from the Catalog Item in question
2) Add a For Each using the Array.Object from Step 1
3) Perform a Look Up Record
Bot the String for the column in the Array Object and the Item in the For Each loop are greyed out and unable to be selected.
Have I missed something obvious?
Rosemary4
If anyone encounters this problem in future, the steps to resolve are:
  1. Save your Flow
  2. Type "cache.do" in the filter navigator and hit enter
  3. Wait for the information screen to display
  4. Refresh your Flow Designer tab
    The datapill in the "For Each" loop is now available for use
9 REPLIES 9
Rosemary4
  1. Save your Flow
Thank you, this was driving me mad!
OMG -  Thank you for this -  I spent hours trying to figure out what was going on here!
Hi @Rosemary4
I have one requirement on MRVS
When a Catalog Item is submitted with multiple MRVS rows, we need one SCTASK created per row this is done through flow, and each SCTASK should carry only that row’s data.
A Catalog Item (RITM) with an MRVS (task_details) containing multiple rows.
Each row has fields
Expected Output:
For every MRVS row, a separate SCTASK record is created. and for each line row data should add to the one single line text variable.
please assist on this
You might want to try starting a new thread asking the community.
