Problem Password reset process
Domenico Nolfi
Giga Contributor
Good morning,
I'm testing the Self Service Password process provided by ServiceNow but even if the account is valid, I received an error message.
I attach screenshot.
As far you can see below, the plugin is configured as Standard
Can you help me to understand the problem ?
Many thanks,
Domenico
Hi GB, I don't have a "Default Self Service 1" process, did you create it by yourself ? can show me the details ?
Thanks a lot.
Domenico
Hey Domenico,
All are OOB processes. I will recommend you get a personal Dev instance so you can compare. Here are the screenshots.
Domenico Nolfi
Giga Contributor
I have this configuration now, but I have the same problem. It's not my personal instance.
Could you please check the logs:
Password reset -> Activity Logs
Check what is causing the error so we can troubleshoot further.
Also, could you please try the "Default Self Service 1" & Disable "Default Self Service"
GB
