Retain existing values using field map script
Evren Yamin
Is there a way to retain existing values of the field when using a transform map?
My requirement is for example I have this record on group table:
group name = cab approval
type = itil
Then I'm using transform map to update this record. The data I'm loading for example is:
type = catalog
What needs to happen after transform is:
type = itil, catalog
I need to retain the existing value of the type field on the group table after transform. If not empty then update, if empty then inser
Appreciate all the help.
The code does not implement the part where it is supposed to check whether the current list already contains the item to be added. I would go with a field map script as below:
answer = (function transformEntry (source, target, action, log) {
	var groupTypeUniqueValues = getGroupTypeUniqueValues('' + source.u_sys_user_group_type);
	return addTypeToNewGroup(action, groupTypeUniqueValues) ||
		addTypeToGroupWithNoType(target.type.nil(), groupTypeUniqueValues) ||
		addTypeToGroupWithType(getGroupTypes('' + target.type), groupTypeUniqueValues);
	function addMissingTypes () {
		return function (existingValues, newValue) {
			if (existingValues.indexOf(newValue) < 0)
				existingValues.push(newValue);
			return existingValues;
	function addTypeToGroupWithNoType (typeIsEmpty, value) {
		if (typeIsEmpty)
			return value.join(',');
	function addTypeToGroupWithType (existingValues, newValues) {
		return newValues
			.reduce(addMissingTypes(), existingValues)
			.join(',');
	function addTypeToNewGroup (action, value) {
		if (action == 'insert')
	function getGroupTypes (groupTypeList) {
		return groupTypeList
			.split(semiColonCommaOrNewLineSorrundedByWhiteSpace())
			.filter(retainNotEmpty())
			.filter(retainUnique());
	function getGroupTypeUniqueValues (groupTypeList) {
			.map(getUniqueValueFromDisplayValue('sys_user_group_type'))
	function getUniqueValueFromDisplayValue (tableName) {
		return function getUniqueValueFromDisplayValue (displayValue) {
			return '' + GetIDValue(tableName, displayValue);
	function retainNotEmpty () {
		return function retainNotEmpty (item) {
			return item != '';
	function retainUnique () {
		return function retainUnique (item, index, items) {
			return items.indexOf(item) == index;
	function semiColonCommaOrNewLineSorrundedByWhiteSpace () {
		return /\s*[;,\n]\s*/g;
})(source, target, action, log);
answer;
Tested it with a field map setup in a transform map as below:
		if (typeIsEmpty)
		return newValues
			.join(',');
			return item != '';
answer;
