08-03-2016 04:18 PM
Is there anyone here using ServiceNow as a Document Management Solution? I just wanted to know about your experiences and what applications you used, eg. Managed Documents, Knowledge Management, any custom applications etc. I would also like to ask about your workflow, ie. how you go from creating a document, to managing the different document versions, and if there are applications (even if it is custom) that you can use to edit documents from within ServiceNow rather than needing to download them, editing on your desktop using Microsoft Office/Other Desktop Apps, then uploading it back.
- 24,046 Views
10-26-2016 04:10 AM
Well, it was like 6-9 months ago (Pre helsinki version) that we took a look at it and I wasn't the primary one looking deeper into it.
For background we were using Sharepoint at the moment(think my former job still does as well). So that is the one we were comparing against.
This is the fragments 😃 I can remember and most of this was what we could find our self. So some of this things might not be true, it's just that we didn't find it.
- Doesn't have the version handling with checkout doc etc. like you can do in sharepoint.
- Didn't either find a good way to handle versions and approval flows.
- Couldn't find any good reference customer with ServiceNow that was using it and where we could come and see with our own eyes how it should be done.
- But the thing that I know made us take a step back was that it doesn't seem to be so much information about it and when we went to Knowledge 16, we couldn't find a single session about managed documents, which made us start thinking how much does ServiceNow value this functionality, Will it evolve in future release or slowly decay? I takes a lot of work to move everything into ServiceNow and at that point, we didn't feel secure enough that till would be solution that will be usable for many years.
Hope this helps you thinking about Managed Documents. But like i wrote, it was pre helsinki. I haven't had the time to look if there been any major changes in Helsinki or Istanbul version.
//Göran
06-10-2024 08:56 PM
Hi, there is an update to this forum post. Any forum posts before 2023 are likely not to have the correct updated information on this topic. The document management system has been revamped as of Rome "Managed Documents" being replaced with "Document Management" as part of Document Services. It was updated again with Tokyo and serves as an alternative to attachments. The topic is not well publicized from what I can tell.
The official docs site for current version is here:
LIMITATIONS OF ATTACHMENTS (legacy ‘managed docs’ plugin vs new 'document management)
–No Document Metadata or search based on Metadata
–No Versioning
–No Lifecycle Management (draft, reviewed, published)
–No Universal Referencing (attachment is always local file to the record, reupload for every record)
–Limited UAC, anyone with access to record can access the file
–No external (public) permalink option for document (if desired)
Comparison: sys_attachments vs ds_document:
Capability |
Attachments (sys_attachments) [legacy] |
Documents (ds_document) [newer] |
Security |
No UAC. Accessible to all users who have access to the record |
UAC - access to file is separated from access to the record. |
Versioning |
No versioning |
Supports versioning, which allows users to track changes to documents over time. |
Searching |
No metadata based search |
Metadata can be searched by name, title, author, and other properties. |
Referencing |
No referencing |
Single document can be referred to multiple parent records |
Storage |
Same document must be attached repeatedly on every record where it would be referenced. |
Same content can be referred to multiple target records |
11-25-2025 08:14 PM
Hi @JC Icaro1,
It sounds like version control and inline editing are the key pain points you’re exploring with ServiceNow. Out of curiosity, has anyone experimented with AI-assisted document management within ServiceNow?
At eesel AI, we’ve been testing ways to summarize, track, and surface document changes automatically, which might help with workflows where you currently have to download/edit/upload.
Would be interesting to hear if others are trying similar approaches.
