Synchronize attachments between Case and Incident
Christophe
Our customers created case via the web portal. Our engineers work in the incident. All the updates that should be visible for the customer are synchronized between case and incident. When a customer adds an attachment to the case, it is not visible in the incident. How can I make this work? I checked the forum and the documentation, but was not really able to find a solution. Thank you in advance for your help!
My pleasure and please start working on scripting by joining the developer's learning on https://developer.servicenow.com.
Kindly,mark the answer as correct if this helps you out so,this questions could be considered as closed for other community members.
Munender
21 REPLIES 21
I now have the following, but I receive quite some errors.
var incGr = new GlideRecord('incident');
incGr.addQuery('<u_case>', current.table_sys_id);
incGr.query();
if(incGr.next())
GlideSysAttachment.copy('<sn_customerservice_case>', current.table_sys_id, 'incident', incGr.sys_id);
})(current, previous);
This ain't good,please share the screenshot of your form .
rEGARDS,
mUNENDER
There they are. Thank you so much for your help!
You can use code like this:
incGr.addQuery('u_case', current.sys_id);
incGr.query();
if(incGr.next())
new GlideSysAttachment.copy('incident', incGr.sys_id, 'case', current.sys_id);
Munender
The attachment is added to the Case, but does not sync to the Incident. 😞
