Synchronize attachments between Case and Incident
Christophe
Our customers created case via the web portal. Our engineers work in the incident. All the updates that should be visible for the customer are synchronized between case and incident. When a customer adds an attachment to the case, it is not visible in the incident. How can I make this work? I checked the forum and the documentation, but was not really able to find a solution. Thank you in advance for your help!
My pleasure and please start working on scripting by joining the developer's learning on https://developer.servicenow.com.
Kindly,mark the answer as correct if this helps you out so,this questions could be considered as closed for other community members.
Munender
21 REPLIES 21
What if I want to have checkboxes to select which attachments I want to transfer and which to not.
Anu
Vattem Sandhya
Hi
In our case attachments will copy from case to incident or change but it will copy after update any attachments on case.
what I need is if case is attached to any attachment initially that will copy to incident/change.
Thank you in advance for your help.
