Trying to call script include from reference qualifier but not getting the correct groups in the catalog item
I have requirement that there is one catalog item with two variables User and Group. User is of single line text variable and group is reference type variable.
When I click on group search icon, it should display list of only those groups of which currently logged in user is a part but I am getting all groups in the list.
I have created script include for this and calling this script include in the reference qualifier field of group variable of the Catalog item.
I have attached the required screenshots.
Pls help me to find what is wrong with my code.
Below is the script include I have written-
var GetUserGroups = Class.create();
GetUserGroups.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getGroups:function(){
var arr=[];
var grp=new GlideRecord('sys_user_group');
grp.addQuery('active',true);
grp.query();
while(grp.next())
if(gs.getUser().isMemberOf(grp.name)== true)
arr.push(grp.name);
return arr;
type: 'GetUserGroups'
Afsar
Hi @Afsar
Finally, this will solve your issue:
Update Script Include:
var GetGroupMembers = Class.create();
GetGroupMembers.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getMembers: function(userId) {
		var groups = [];
		var getMyGroup = new GlideRecord('sys_user_grmember');
		getMyGroup.addEncodedQuery('user.user_name=' + userId + '');
		getMyGroup.query();
		while(getMyGroup.next()) {
			groups.push(getMyGroup.getValue('group'));
		//Added log to see what data is generated
		//gs.log('[DEBUG] Groups for User ID: ' + userId + '\n' + groups);
		if(JSUtil.notNil(groups)) {
			return groups.join(',');
		} else
			return '-1';
    type: 'GetGroupMembers'
Reference Qualifier:
javascript: 'sys_idIN' + new GetGroupMembers().getMembers(current.variables.<backend_name_of_user_variable>);
Check the screenshot as well:
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
17 REPLIES 17
Kartik,
still it is not working.
Hi @Afsar
Did you make changes to the Reference Qualifier as well?
Also please add the log message as provided below:
GetGroupMembers.prototype = {
		var groups = [];
		getMyGroup.addEncodedQuery('user.user_name=' + userId);
		getMyGroup.query();
			groups.push(getMyGroup.getValue('sys_id'));
		if(groups) {
		} else
			return '-1';
Please let me know what results you are getting.
Thanks and regards,
Kartik Sethi
NO Logs generated.
And added the reference qualifier field as following:
javascript: new GetGroupMembers().getMember(current.u_user)
See the screenshot as well for the updated script include and reference qualifier.find_real_file.png
Hi @Afsar
		var groups = [];
		getMyGroup.query();
		} else
			return '-1';
Thanks and regards,
Kartik
Thanks a lot Kartik....
It is working now..
